FT View SE Tags Not Working
southerndandy
Apr 2007
British Columbia
Hello all!
I am having some issues with Rockwell's FT View SE Studio software.
I'm trying to get a test tag I created in the tag editor to work in a display. For some reason when I use a 'direct' tag (as I think its refered to) the indicatior works as it should when I toggle the bit in the SLC 5/05. When I tell the indicator to use one of the tags that I created which references a 'direct' tag, the indicatior doesn't function. It doesn't go into the error state (at least not right away) - it just remains in state 0.
I have gone through the SE manual / help in the software and tried everything I could thing of with no luck. I see that Rockwell has a Knowledge Base answer 61014 that matches my issue but in true Rockwell fashion they have it locked away for peoples with a Tech Connect contract which sadly I do not have...
The SE setup is pretty basic. I'm using RSLinx Enterprise as my 'data server' with one 'area' and a few display screens - nothing overly complex that for sure. Any help would be greatly appreciated.
Thanks much!
I don't have any experience with your problem but, here is the 61014 answer:
Question
Why do my tags not work when used in the tag Database but direct tags do.
I am using RSView SE and RSLinx Enterprise as my data server.
Answer
Restoring a backup of the project failed and this indicated that the tag database was corrupt.
Steps required to recover a corrupt tag database.
  1. Make a backup of your SE project.
  2. Export all the tags from the running project.
  3. Delete all the cache files in the backup [Project\cache\RDMDATA].
  4. Delete all the files in the backup tag folder [Project\TAG] (Make a note of the file names).
  5. Create a new blank project with HMI server.
  6. Copy all the files in the TAG folder of the blank project to the TAG folder in the backup project rename all the files to match project name as noted in step 4.
  7. Create a New Project.
  8. Import the HMI server from the backup copy used in step 6.
  9. Import all the tags from the CSV files created in step 2.
The above steps should recover the system and the tag data base should now work correctly.
Hi, I am having this rather strange issue. In my FTView SE application (FTView SE 6.1), I have an area where I display current time and date. I...
6,109
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
95
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
411
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I...
657
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
