FTVME 5.00 Protected data entry
jdbrandt
Oct 2002
Pennsylvania
1,203
Rockwell Factory Talk View ME, version 5.0
I want a numeric entry, but password protected.
In other words, I want to show the number all the time:
XXX.X
But, when the right account is logged in, it looks the same:
XXX.X
but when you TOUCH it, a data entry box pops up.
I have the password part figured out.. CurrentUserLevel() ...
and I can make text appear and disappear.
But, how do I do this.
I'm sure its simple...Animation, Visibility, but WHAT?
Can you create a transparent button and place visibility on that button CurrentUserLevel(X) and then have a numeric display that is visible all the time.
I say visibility on a transparent button but it should only be active for the correct user.
Clear as mudddd..Hope this helps
Hi, We don't do many Rockwell projects but recently did onw with a Control Logix and Panelview. What files do customers expect when you send...
263
So I have a PVP7 with keypad and a trend screen setup. I started fumbling around with buttons and managed to move the trend forward and backward...
942
I was about 9/10 done building a new HMI program using both HMI tags and direct reference tags. I was testing it to make sure all of the bugs were...
1,679
I am trying to replace a Panelview Plus 600 from a machine. The HMI works it is just damaged on inside plastic and won't stay together. I uploaded...
1,305
While creating a runtime, the progress window shows: compression Tag\ABC1_ABC.db.wat The ABC1_ABC is a project\target\tag\???? from a previous...
1,553
