FX3U Compatible with E1071?
Cryometrix
Dec 2014
Utah
20
Does anybody know if the FX3U-16M is compatible with the E1071? We are having communication problems and the manual only lists GOT Series HMI's are compatible with the FX3U-16M. Thanks for your help!
-Steve
Hi!
I would hope so, they are both made by Mitsubishi :).
I think you need the CAB19 cable to connect.
Send me an email and I can send you a program we used "back in the day"
The E1071 is actually manufactured by Beijer but re-badged Mitsubishi. The Beijer version is called EXTER T70, but instead of using "E-Designer" you use the virtually identical "Information Designer".
As mention by boneless you need a Cab 19 cable.
Are you trying to connect via Ethernet by any chance?
wow thanks for all of the replies, we were trying to connect it with a CAB19 cable but it was not communicating. This is all coming from my programer. I will get more info from him and post it up tomorrow probably. thanks for your help
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
230
Hi All, want to ask. I have PLC a programme to control the valve. The existing programme is to control valve A (Y22), and I want to change to...
161
Dear all, I don't know why setup of password became challenging and weird. After setting up the password and try to upload the ladder from the plc...
189
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
245
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
179
