FX3U-ENET Communications
megavolt818
Jul 2007
Connecticut
I currently have a ENET module connected to a FX3U PLC. I have the ENET connected to a computer that is running a custom user interface. I am running an OPC server on the computer. Everything is working great except that I am not able to recover from a communication error. For example, I will have everything working just as it should and then I unplug the ethernet cable from the ENET module. The COMM> ERR light will come on. I plug the cable back in and I am not able to re-establish communications with the ENET module. I can PING the module's IP address, but the OPC server will not communicate with the ENET module. If I power the PLC and ENET module off and then back on, communication will be re-established. How can I re-establish communications without have to turn the power off and then back on. It there a setting that I am missing?
Thanks,
hi All I am completely green in Mitsubishi PLC (i used to program siemens) but need kepware to connect to FX3U pls with ENET adp module. Could...
31
7,143
Hello, I have an FX3u-16MR/ES, FX3u-ENET (version 1.0), using GX Works2 Version 1.596W (Trial version). Using FX Configurator-EN...
5,030
Hi all, I have finished installing ethernet adapter module FX3U-ENET-ADP on the FX3U-48M PLC. From the ethernet module, i connected it to a...
3,382
Good morning all I've inherited a PLC system that has two Q01 and 6 FX2n PLCs The FXs have a FX3u-ENET module. There is quite a bit of...
6,272
Dear all, Can you please tell me how to program an FX3U PLC through an FX3U-ENET-ADP. Thank you
1,614
