Fx3u-enet connection problem
RheinhardtP
Oct 2004
Perth
562
Hi Gents,
I am having the following problem. I hvae a FX3u-Enet module that communicates to a 3rd part pc. Underneath is my config.
Initially after power up when i connect to my communication pair both connections are opened(Connection 2 & 3). The problem comes when this connection falls away and then tries to reopen these connection. At first it would only connect to the send connection when i disconnect and reconnect it only connects to the receive connection. I have attached Ethernet diagnostics.
The screens are under following conditions.
NXAutoConfigure.jpg -- Configuration settings
NXAutoConnect.jpg -- Initial connection. Works 100%. Send and Receive
NXAutoDisConnect.jpg -- Initial Disconnect from 3 rd party
NXAutoConnect2.jpg -- When connecting a second time. Only Receive works.
NXAutoConnect3.jpg -- When connecting a 3rd time. Only Send works.
Afterwards it toggels between the two and i cannot get both open.
I have tried to re-initialize using code but it does not make a difference.
Any idea what could be causing this?
NXAutoConfigure.JPG NXAutoConnected.JPG NXAutoDisconnect.JPG NXAutoConnected2.JPG NXAutoConnected3.JPG
hi All I am completely green in Mitsubishi PLC (i used to program siemens) but need kepware to connect to FX3U pls with ENET adp module. Could...
31
7,114
Hello, I have an FX3u-16MR/ES, FX3u-ENET (version 1.0), using GX Works2 Version 1.596W (Trial version). Using FX Configurator-EN...
4,972
Hi all, I have finished installing ethernet adapter module FX3U-ENET-ADP on the FX3U-48M PLC. From the ethernet module, i connected it to a...
3,363
Good morning all I've inherited a PLC system that has two Q01 and 6 FX2n PLCs The FXs have a FX3u-ENET module. There is quite a bit of...
6,213
Dear all, Can you please tell me how to program an FX3U PLC through an FX3U-ENET-ADP. Thank you
1,606
