FX3U ENET Email
jmdotso1
May 2008
Texas
I am trying to use an FX3U ENET module to send email via SMTP and keep getting a C102 error. I can ping the SMTP via the diagnostics tool in FX Configurator with success but everytime my PLC code initializes a send the ENET gives this error. I am using a POP type email that uses port 110 for the receive and port 25 for the send. It does not use SPA nor does it require authentication. The username and password are correct as they work fine from Outlook. Has anyone tried doing this with success and if so can you please guide me on what I'm missing? Thanks.
Problem Solved
Didn't realize that the router relay parameter had to be setup. Once this was added the email function is working well.
hi All I am completely green in Mitsubishi PLC (i used to program siemens) but need kepware to connect to FX3U pls with ENET adp module. Could...
31
7,132
Hello, I have an FX3u-16MR/ES, FX3u-ENET (version 1.0), using GX Works2 Version 1.596W (Trial version). Using FX Configurator-EN...
5,018
Hi all, I have finished installing ethernet adapter module FX3U-ENET-ADP on the FX3U-48M PLC. From the ethernet module, i connected it to a...
3,378
Good morning all I've inherited a PLC system that has two Q01 and 6 FX2n PLCs The FXs have a FX3u-ENET module. There is quite a bit of...
6,256
Dear all, Can you please tell me how to program an FX3U PLC through an FX3U-ENET-ADP. Thank you
1,610
