G.E. OpenProcess FBD
Do you program with
  • Total voters
  • Poll closed .
kmh
Nov 2018
Colorado
Anyone familiar with OpenProcess Function Block Diagramming. I'm analyzing some old 2001 drawings and need functional descriptions as well as parameter descriptions for some of the blocks, especially the MA_AU block. Also, I don't understand why outputs are connected together. I've attached a pdf.
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
141
Hardware: 5069-L320ERMS2 Software: Logix Designer 35.11 / Ignition 8.1 Issue: When attempting to write to the tag "HMI_DRV200_DynamicTrim" in...
774
Hi, I'm using Control Expert (a.k.a Unity Pro) to program M340 PLC. I am looking for a patch to fix what I think is a bug in PLC library. Please...
1,044
Hi, does anyone have experience with the Off Delay Long Timer function in GX works 3, I need a PV greater than T#2147483ms If I use Long Timer...
1,231
Hi. I haven't touched RSLogix since at least 10 years and I'm a little lost. I spent most of these years on Unity Pro. but now the customer...
638
