G308 -> csmstrsx
DLMUK
Jun 2013
Southampton
311
Hi all,
I am trying to connect a CSMSTRSX (with a CSINI8 attached) to a G308 via the ethernet ports.
I have set my G308 as a Modbus TCP/IP master (under the communications tab > Ethernet Protocol 1). The IP address of the G308 is configured manually to 192.168.1.20.
I have set the CSMSTRSX IP to 192.168.1.23. Under the commications tab I have set up Ethernet Protocol 1 to Modbus TCP/IP Slave.
I have two inputs into my CSINI8 module, both 4-20mA. I have created two gateway blocks in my CSMSTRSX for these, #1 is 400050 and #2 is 400060. I have mapped the inputs (PV1 and PV2) from CH1 and CH2 of the CSINI8 to these gateway blocks. (device direction is set as G3 to Device - but to my knowledge this is irrelevant as my CSMSTRSX is a slave device - it will also not allow me to change this).
I have created two data tags on my G308 to get their values from the CSMSTRSX in holding registers 400050 and 400060.
However when I turn it all on I get no input to the G308 from the CSMSTRSX. The lights on the ethernet ports are not flashing at all.
I have checked both devices by loading the database via ethernet and they worked. I have checked my inputs and they are both present and correct.
To me it seems like the two devices simply are not communicating but I cannot think why not. Its been a while since i've used Red Lion.
any help would be appreciated.
Many thanks,
What is your ping holding register set for?
Are you connected directly with a crossover cable or going through a switch?
Before I start down this rabbit hole I should just ask. Can an easy conversion from the red lion G308 to red lion CR3000 be done with crimson...
1,262
Hi, new to the forum, and desperate. I am trying to connect a RedLion G308 via ethernet to a Logix 5562 PLC. I am connected via a switch directly...
1,792
I'll try to simplify this as much as possible... I have a G308 that acts as a webserver dashboard and collects misc data (bottle counts, bottles...
18
4,024
Hi all, I'm trying to figure out how to capture data that is randomly sent by pin making device to g308. It seems like port has some buffer where...
1,787
Hi all! This is my first post after reading so many. I have a redlion g308 connected to 2 panasonic fp-x plcs. One is via rs 485 which works...
1,400
