This is my first time using RS232 with GE.
Module is CMM311. Device is RS232, DCE, 2400,8,1,none.
It's a controller that reads vacuum. The vacuum scale is in Torr. 760 Torr is atmosphere - anything below 1 Torr or so would bottom out a standard vacuum gauge. High vacuum is much lower than 1 Torr. To make it simple, the entire range is represented exponentially. Range is 760 to 1.0x10-9 Torr.
Command to read gauge 1: "=RV1"
Response at low vacuum: "1.0-04"
Response at High Vacuum: "1.0-09"
The range for RV1 and RV2 will always be negative.
RV3 through RV6 will be both:
Command to read gauge 3: "=RV3"
Response at atmosphere: "7.6+02"
Response at low Vacuum: "1.0-03"
Questions:
Do I use CCM on port 1 for the format?
How do I convert the ASCII characters returned into a real number so I can compare the reading to a setpoint?
Keith
Questions:
Keith
