GE ENET station manager
jjack230
Aug 2017
Brisbane
Hi
I am just starting out at a new job full of GE systems.
I have a IC695ETM001 ethernet card which has a RS232 port for Station manager access.
I can currently see some info (such as IP, firmware version etc.) from the card when I connect with Putty and cycle the power but I cannot send commands to the card. I've tried Putty, hyper-terminal and a standalone Station manager terminal from GE but nothing works.
Anyone know whether I'm missing something?
I'm wanting to do some monitoring on that card. We've put in a replacement time and time again. Every card that goes in has the "Log Empty" indicator light turn off after 30 seconds. So I want to view that log.
I found the issue.
Turns out that you need the serial cable provided by GE.
You can't just use a standard cable. Haven't checked the wiring configuration but theres something different.
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
61
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
169
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
143
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
165
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
151
