Hello Everyone,
I have installed a IC200UEM001 Ethernet Module on my VersaMax PLC. I can set the Temporary IP Address using PME 9.0. The issue is when I go to set the permanent IP using the instructions (See Attached) provided it is not working.
Here are the details: I am following the steps on page 2 of the manual under Setting the Permanent IP Address
1. No problem here I can ping the temp. IP address.
2. This works also I see several entries returned.
3. What returns is: 'arp -s' Is not recognized as a internal or external command, operable program or batch file.
4. I get a reply similar to #3: 'telnet' Is not recognized as a internal or external command, operable program or batch file.
5. Same reply as #4.
My computer uses Windows 7 Pro so I don't know if that makes any difference since the instruction manual was written over 3 years ago.
Any ideas how I can set the IP permanently? I am really at a loss as nothing I do seems to work.
Thanks!!
Thanks!!
