GE Fanuc 90 30 info
leitmotif
Nov 2004
Seattle Wa. USA
3,680
We have several machines with GE Fanuc 90 -30 PLC in them. I know a little on Allen Bradley / Rockwell but nothing about GE Fanuc. We have no manuals.
Where can I get study material so I can learn how to deal with at least the basics?
Where can I get manuals?
I suppose I should have make model serial number of the unit, but I just saw it today (on job 40 days and no I am not Noah and it hasnt rained in Seattle for at least a week -- hooray)
I can see my education continuing
Dan Bentler
You can go here:
http://support.gefanuc.com/support/index?page=docchannel
Under "Product Family", select "Controllers & IO"
Under "Product Name", select 90-30
Under "Categories", select "Manuals"
The hardware manual is GFK-0356*. The last character of the publication number is the revision level.
For an instruction set manual, I like GFK-0467*. It was written for the old DOS Logicmaster software, but in my opinion it is more thorough than more recent manuals.
You might also want to download GFK-0898*. That has the specs and wiring of the I/O modules.
There are also manuals written specifically for the special purpose modules. If you can identify what modules you have over and above the discrete and analog I/O, I can identify the publication numbers you need to download.
Steve Bailey said:
You can go here:
Thank you Steve
Looks like I got some reading to do.
Dan
I've found that for most basic apps, GE and AB are programmed so similarly that it's easy to switch between them, programming wise. The big difference is GE's more specialized commands.
If you know what type of function you are looking for, it's pretty easy to find. I actually like the editor in Proficy (and the prior GE products) a lot. In some ways it is better than AB editors. And I'm an AB man...
Hi everybody greetings from Germany, i am looking for some informations about GE Plc´s. We have a vessel equiped with a Network of such PLC´s. I...
2,895
Happy festive greetings to all, As part of my learning process on PLC I was able to visit a manufacturing plant that uses only GE PLC. Until now I...
1,447
Does anyone have any good resources, web sites, etc.. with information or discussion on older Fanuc CNC controls? I live in a small town in the...
5,387
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
112
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
112
