GE QuickPanel IP Address Change
PLCPRO1
Apr 2015
North Bay
Hello,
I recently inherited some equipment into our plant. This equipment has a Compact Logix PLC, Yaskawa Motion Controller, and a GE QuickPanel (#IC754VBI12CTD-FG). I would like to change the IP addresses of these components so I can set them up on our plant network. I am able to change the PLC address, and the motion controller address, I Have the sofware for those. however, I have the Proficy software but don't have the Licence for it, Only running in Demo mode.
I should be able to change the QuickPanel Address through the Windows CE interface. But I need to change the Target PLC address so they can Communicate afterwards.
My Question is: Is it possible to change the IP address of the target PLC in Demo Mode, or is there another way I can change this?
This is the only GE QuickPanel in our plant. I don't really want to pay for another Licence just for this one touch panel. I have plans of replacing this panel with what I current use in our plant.
Any Help on this would be Appreciated.
If you are operating in "Demo" mode you cannot download to the QuickPanel to change the PLC Access Driver's IP to match the new PLC IP. Also you cannot save any changes to the hard disk.
You can un-install Proficy ME and re-install it to get 4 days of "Trial" mode in which you can download and save everything.
While working with it I suggest that you get a small Compact Flash card and "Copy Project to CF" in the QuickPanel as a backup.
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
345
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
665
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,789
does anyone know if you can make a graphical panel with the quickpanel+ 7inch that you can only open with a password? for example a panel where...
1,825
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,030
