GE RSTi-EP Remote IO?
NetNathan
Nov 2011
Corona, CA
2,199
Has anyone used these modules?
Comments?
I am doing a 24VDC RX3i system with Profinet to 2 RSTi-EP remote IO racks Curious about any setup issues and the RSTi-EP Analog and Digital IO modules.
Personally I have not used the EP line but I have coworkers who have installed them on conversion projects in place of Genius blocks. No issues that I know of.
I am considering them on an upcoming major marine project, for that specific purpose, Genius block replacement. Depends on marine approval status when the project engineering begins.
The easiest & quickest RIO I ever worked with. But do yourself a favor and get the documentation (IPIs) and read them before you start. But that will keep you out of the assumption trap for any new to you hardware or software. :)
I have been reading all the info on the modules I plan to use..
It is a little complicated...I have 4 seperately fused 24VDC signals for:
Power supply (Profinet Comm Module)
Digital Inputs
Digital Outputs
Analog I/O
I assume I need these modules to do that?
EP-8631 RSTi-EP Base Connector, Power Feed, Input Current path (for Digital Inputs)
EP-8641 RSTi-EP Base Connector, Power Feed, Output Current path (for Digital Outputs)
Now do I need 2 more for the Analog In and OUT, just run same 24VDC signal to both modules?
Hello, I recently started working at a place that uses Emerson/GE. They have installed some newer RSTI-EP remote I/O replacing the old genius...
175
Good day Programmers I have a RSTi-EP CPE100 Standalone Controller from Emerson as well as a STXMBE001 (MODBUS TCP/IP) as a Modbus communication...
639
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
237
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
285
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
90
