GE Versamax instruction question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I have a GE Versamax micro and am studying a project I uploaded. I have software and it explains the different "references" and symbols however, there is one that I can not find in the book. I attached it here. I did notice that this particular output is an input on the next rung. Probably the association of the two has something to do with this symbol but I can't find it. Thank you
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
231
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
142
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
403
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
443
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,265
