Gear changes' effect on motor current
Kev77; said:
@Okiepc, I can't wait for the OKC and the Lakers, sending Kobe home early will be sweet! But then the Heat will take it all...
have you not heard of the Spurs?
They are considered a favorite in the matchup against the Thunder, even by Homers Newbies here like me, who know little to nothing about Basketball. I couldn't watch the sport until I went a little deaf in the high frequency ranges.
Too much squeaking...reminds me of work and makes my subconscious nag me to look for a grease gun...I love listening to games while doing other things, and the fights needed my eyes more than ears...Matt Pinto on the Sports Animal...I can listen to that station 2-3 hours a day and get pumped up for radio like an old man in the '20's
PG13 Warning: Football season is just around the corner though...
I think the Spurs are a little old and will be out of gas! I was a Laker fan until Shaq was pushed out. Now I am a Blazers fan even with the performance of this seaon. Basketball on the radio is the best. I listen to the even when I am watching it on tv.
I want to do that for college football, but the delay messes it up. I downloaded a free app to add a delay to the audio, but I haven't set up the right cables to do that. I think I am going to invent pand-do-it crown molding and baseboards, and end my cable night mares once and for all.
OK, back on topic...(maybe)
I've got a question on how you approach sizing the correct drive for the application.
Let's say that you have a 80 ft long 24" wide belt conveyor and the belt is on rollers. The driven roll is 12" and the target speed is 100 FPM. The motor will be a 1750 RPM and the overall ratio will be 50:1. The conveyor will carry about 70 cu/ft of wet saw dust at about 18 lbs per cu/ft. What is the ft/lbs needed to do the job? I know how to find the HP required when the torque is supplied.
Sorry OkiePC, I hope I am not stealing your thread.
o_O
If you make the crown molding, I'll buy it!
Has someone tried MC_TorqueLimiting along with MC_GearIn , on a Siemens S120 axis , controlled by an S7-1500T plc ? If we limit the torque ...
1,631
Hello Everybody, Recently we changed the gearbox which has different ratio than the original one on a motor which is controlled by Micromaster...
1,918
Hello, Does anyone know the preset thermal limits for SEW Movigear SNI B drives. Randomly experience overtemperatures of the heatsink of the...
729
Gents, We have several machines where we use 1 till 25 baseplates to make products. Depending on the type of product, we use more or less...
1,420
Hi everyone. I have a micrologix 1400 HSC reading a prox on a 40PPR large diameter (12") gear. This gear has large trapezoidal teeth. 500 RPM max...
41
12,593
