Generic Serial or Ethernet IO
ihc
Dec 2004
North East
Hello all, hoping someone can jog my memory. I am looking for some IO blocks, approx 20 Outputs and 5 Inputs that can be controlled directly from Serial or Ethernet, i.e. not specific to any processor. I know i looked at these a while ago to give IO from a PC but now can't remember who the manufacturer or supplier were. I am hoping to run these from a robot which has both Ethernet and Serial ports (programmable within the robot code). Any pointers would be much appreciated.
I've used Opto 20's I think they were many years ago, not sure if they are still about or what the modern equivalent are. I would think there would be a lot of choices.
Weidmuller used to do IO which used a very simple ASCII protocol. I am not sure whether it is still available but it is worth a try. Alternatively Modbus is generally easy to implement if your processor can handle the CRC calculation. This used to be heavy going for many basic PLC's.
Andybr
Not sure if this is even possible but I have an micro 1400 that I would like to connect to HMI. I am using rs232 from PLC to (RS232/ttl converter)...
232
I know, there's tons of resources out there on how to setup generic ethernet devices but I just cannot figure this out, I'm not sure what I'm...
456
Hello Team, I am working on a project utilizing the new implicit communication with the 208-L50E-***** (specifically a 28QWB). this is a two...
681
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
626
Do you have a recommendation for a low count IO system that you would stand behind for a remote site? It 1.5 hours drive time to the site. I...
963
