Generic Ethernet/IP IO
JeffKiper
Jun 2006
Indiana
2,460
Do you have a recommendation for a low count IO system that you would stand behind for a remote site? It 1.5 hours drive time to the site.
I have a 2 tanks that have 4 floats each. Small simple system. Probably a CompactLogix for controls. I can use AB, bit 1734 Point adds up quick for 4 pooints of IO
I've been thinking about Turck IO blocks. Just figured I would see what else other guys are using.
I'd be using a 1769-L16ER-BB1B. 16 DI and 16 DO onboard, not much else required. If you're already thinking of doing CompactLogix, it seems the obvious choice
I need a PLC in the control room. The tanks are a few hundred feet away from the PLC thats why I was thinking Ethernet
Oh, right.
I mean "a few hundred feet" is pushing up against the limits of ethernet, and over that distance the cost difference between running a 12 core flex to a j-box, vs an ethernet cable to a RIO panel, is probably negligible - I'd still do the L16ER and use the onboard I/O personally.
But that's not the question you asked - personally I haven't dived much into the "small I/O count remote I/O" market, so I'm of limited help - but I do know that others have suggested using an Ethernet Click Koyo as remote I/O. I've got one of those on my balcony running a ridiculously over-engineered watering system and it's been there since 2017, without missing a beat.
I've used IO-link boards for similar, may need an ethernet switch out there to meet your distance. A similar alternative to Turck based on sensor type.
A “few hundred feet” of copper Ethernet is within reach if “few hundred feet” really means “less than one-hundred meters.” In other cases, a small switch with SFP interfaces for a fiber run will work.
Turck or AB ArmorBlocks are robust, provide lots of spare IO, and can be directly mounted without need for an enclosure.
I know, there's tons of resources out there on how to setup generic ethernet devices but I just cannot figure this out, I'm not sure what I'm...
452
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
614
Hello all, I need to add a module in logix for an SMC pneumatic valve manifold specifically EX600-SEN3/4. The eds files I add crash the program...
681
So Rockwell PLCs have some generic ethernet module options available in the IO tree configuration. With the standard generic ethernet module, you...
734
​Hello everyone, I triyng to link a Power Module eMB-60R from Robot Adept Viper s650 to CompactLogix, version 19.11 I followed exactly the...
2,655
