Getting Belden VFD into Panel and Sealing
Tim Ganz
Dec 2010
Dallas, Texas
689
I am wiring a machine that has 2 VFD’s and using belden non armored VFD cable per spec.
Does this have to run in cable tray or can it be pulled in conduit? Spec sheet does not say either way.
Also the grounding glands show to go to the motor and to the bottom of the VFD so how if not running in conduit do you get this into the panel in a sealed way to maintain the panel dust rating as this is a dusty area without using a grounding gland
Seeing that you are in the US, you can only run that cable in tray if it has a TC (Tray Cable) rating, which should be stamped / printed on the jacket. Many of them do, but we don't know what you are using.
You can get sealing grounding fittings for that cable.
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
58
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
83
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
616
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,415
Good morning guys; Im new at AB plc, and i just need help about a table or a list called something like "exchange data table" in French it is...
778
