Getting Compiled code from ABB PLC
marvin99
Jul 2018
Sweden
I have an ABB AC500 PM-582 PLC, The question is... is it possible to get the compiled code out of the CPU, i need to have this as a backup for future CPU replacement only. Is this something that can be done with these ABB PLC's ??
Rgds
Marvin
Unless it is locked you should be able to upload from PLC to engineering station with ABB Automation Builder.
I have been looking around in Automaton Builder, can't find anything related to Uploading the Compiled Code, only stuff that has to do with project files Upload/Download.
Do you have any idea on how this can be done ?.
Unfortunately i don't have the license hardkey in the office right now so i cant start up the application and check.
But automation builder is based on codesys and in codesys you can do it in menu File> Source Upload.
What I am stuck with at the moment is that I'm unable to find my PLC in the device list when creating a new project, the CPU I have is PM582-ETH 1SAP140200R0170, instead what is available to chose is PM582 1SAP140200R0201. because of this, each time I try to login I end up with a Target Difference Error (The Selected PLC profile does not match the profile of the target!)
Any idea what I'm Missing ?
Can you try to upload the programing with a blank project?
Otherwise maybe try calling ABB and ask to talk to PLC support, or write them an email. I've been in contact with them multiple times and they are great support.
Have tried that but looks like you have to create a project to be able to execute these commands.
Do you have any contact details for ABB PLC support ?
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
58
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
84
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
617
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,418
Good morning guys; Im new at AB plc, and i just need help about a table or a list called something like "exchange data table" in French it is...
779
