GP4401WW read timeout through 1747-AIC
alexhughes112
Sep 2019
Milwaukee
Hi everyone,
I have foolishly taken the task to upgrade our older style Proface HMI's from GP377-SC41-24V to GP4401WW. I was able to convert the old .prj program to the new .prx but now I can't get the HMI to communicate to the SLC5/03. We have two HMI's talking to this SLC5/03 through a couple of 1747-AIC's. I purchased a PFXZCBADTM1 Terminal Block and a HMI-CAB-C84 cable. I cut the 25-pin connector off of the HMI-CAB-C84 cable and tried terminating it to the PFXZCBADTM1 Terminal Block. This step confused me because I could not find any accurate diagram on how to connect these. There is an A-side set of terminals and a B-side set of terminals and now I have all like terminals jumpered together. I set my HMI to communicate through COM2 RS422/485(2-wire). My source ID is 0 and my destination is 1. When I have the old hmi plugged into one 1747-AIC and I plug the new hmi into a different 1747-AIC it recognizes that another device is connected with the same source ID, but when I disconnect the old one the read to the plc times out and I get an error. Right now I'm stuck and would greatly appreciate any help I can get.
Thanks,
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
163
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
266
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
103
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
152
