Gx Works2 help
Tradie17
Aug 2016
au
Hi there,
Can someone shed some light on the following instructions:
OUT_C_32
DINT_TO_INT
Thanks.
Hi
OUT_C_32 is a 32 bit counter
DINT to INT is a conversion from double integer to single integer
I would recommend you download a manual
Thankyou,
Yea I believe that's best, forgive me for being stupid, learning all this of my own back.
This is good to know :)
So going back to what I previously asked. In a small program I have OUT_C_32 is the high speed counter for the encoder.
EN=TRUE
CCOIL= CC251
C VALUE=0
Then the next step turns the value of the encoder to a data word.
However I cant find the input of the encoder in the program, it shows in the input tab in global label that X0 and X1 are the encoder, but they are not in the program page.
So where are the pulses going?
Even in the electrical drawings it says X0= encoder A signal and X1 B signal
Pretty sure the IO is defined by CC251, IIRC I found a chart in a manual(somewhere) that outlined the different CC registers and what they were tied too. Depending on the encoder wiring and input selection you had to change the CC register to align with the needs.
IMO Mitsubishi is a huge PITA.
I found the manual I was referencing, it was for the FX3G PLC there is a table on page 162 that shows the counter selections and what IO it correlates too.
251 correlates to A phase on X000 and B phase on X001 on this particular controller.
Hi, I have a project that i have to use a Mitsubishi FX3G with GX WORKS2, wich i never worked with before. I´ve been working with TIA Portal...
3,010
Hi, I am new to Mitsu, know RSLogix 500/5000, micros, etc, and am translating a dynamometer controller application from RSL5000 to GX Works2 on a...
6,056
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
1,037
I'm starting learning ladder programming. I bought the FX3U kit + coolmay HMI from aliexpress. I'm doing basic testing and uploading codes. I...
57
4,070
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
1,001
