GX Works2 vs GX Works3
gleblanc
Oct 2010
Williamstown, WV
What's the comparison between GX Works2 and GX Works3. The new Mitsubishi Factory webpage seems to imply that Works3 only has support for the iQ-F and iQ-R controllers. Does this mean that it doesn't work with FX, or the older Q series CPUs?
Are there any compelling new features in this version? I'm about to receive a whole new assembly line with a Q-CPU (still negotiating which one) as the master controller.
This is correct.
From what I have seen so far, GX Works 3 is still in it's infancy. It's a new development environment and I've had issues with some basic functions which have made it frustrating and cumbersome. Although I can't say I'm much of a fan of GX Works 2 either.
Is this correct? I just bought a copy of GX works 3 to support some new equipment we are installing. I haven't loaded it on my computer yet. The processor on our new stuff is Q04UDEHCPU. Are you saying this software will not work for me? What will work? Thanks.
Q Series requires GX Works 2.
Check the installer files/documentation of the software you purchased, GX Works 2 might have been bundled with it.
Software Link:
https://us.mitsubishielectric.com/fa/en/products/controllers/programmable-controllers-melsec/engineering-software
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
986
I'm starting learning ladder programming. I bought the FX3U kit + coolmay HMI from aliexpress. I'm doing basic testing and uploading codes. I...
57
3,943
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
988
hello, I'm trying to set up communications between two Mitsubishi L series PLCs using the built in Ethernet port. All of the information I can...
1,889
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,387
