The Unitronics M91-2-R1 has an analog input (so you can bring in your transducer measurement), but it has no analog output (so you will not be able to send any new measurement setting out of the Unitronics PLC). You can only read whatever is there now.OK... got the Unitronics M91 device here to play with, and a 12" linear transducer as well.
Your Unitronics M91-2-R1 has an anlog input to read in the existing measurement from your transducer, but it has no analog outputs. If you can send out digital commands (UP or DOWN) to change the measurement, then it will work as is, but if you have to send out an analog number such as "51.75", then you will have to buy an add-on module with an analog output, such as the Unitronics V200-18-E2B.Now I want it to raise to 51.75" by means of a 10-button input. Is there such device?
Do you have a DC power supply (24Vdc) then a 4~20 mA load is easy.The problem I am facing now is the 10VDC (or 4-20ma) 'source' needed to make this work. I have thoroughly searched this forum, but I only see a few posts about hand-built 'calibrators' or 'testers'... Is there a manufacturer that offers a din-rail mounted device that can do the trick? ($50 or so?)
Or get a 9vdc supply and lose 10% of your resolution.the alternative is to purhase a 12 Vdc adjustable power supply these will usually 'Tune down' to a low enough voltage
There are many ways to get a 10 volt output from something. A PLC output driving a relay contact (which is fed by a 10-volt power supply) would do the job. I guess you could do that with one of your Unitronics outputs. Many 12 VDC power supplies can be adjusted down to produce 10 volts.I'm just amazed that there isn't a simple (cheap) way to get a realtively stable 10 volt output from something, since 0-10 volt devices seem to be everywhere!
OK... got the Unitronics M91 device here to play with, and a 12" linear transducer as well. The Transducer is 1K ohm. The Unitronics software is free.
