HELP! Allen Bradley SLC 5/05 fault
I have encountered equally both a bad chasis and a bad power supply. If possible, I would stick another PSU on and see if it solves the problem. If not, then try the chasis. perhaps the same person could loan you spare parts to check with one at a time.
Have you guys done any installs that might introduce noise into this system recently, by chance?
Odds are the power supply is having issues and will short out the CPU and make the program disappear, this I have seen more than once
g.mccormick said:
Chassis power supply starting to die?
I say try changing the power supply :)
Is there an HMI of some kind ?
If so, one more recommendation is to display on the HMI the "major error" status word S:6 and "last major error" status word S:54.
With these two status words, you have a fighting chance to troubleshoot the PLC without going online with RSLogix.
I like how experience speaks! Thanks for your help. I will definitely keep this in the radar. I also figured a bad back plane could cause issues.
Yes, they do have a Panelview as well. Thanks for the suggestion.
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
268
I am having an issue getting a IY4 to read my thermocouple correctly. We have a R type and K type hooked up and sitting at a known room...
536
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,356
Hello everyone, im new in Allen Bradley World, i alredy know how to use factory talk view and with manager i have alredy upload all runtime...
1,705
Hello all, I am in my first year of programming and stuck up on a few things for a project that needs to be completed this week. My boss and...
741
