Help in configuring Woodhead's backplane module for AB ControlLogic PLC.
vaidyaas
Apr 2005
Dear All,
I'm trying to configure the SST-PFB-CLX, backplane module for AB ControlLogix (it enables profibus communication for ControlLogix) by Woodhead Inc.
I want to configure this card as Slave with Siemens 315-2DP CPU as master.
Can anybody help me in configuring this? Has anybody done this before.
Please let me know the procedural steps for this configuration.
Regards,
ASV
hello vaydiass;
I suggest you download the 7150022_PFBCLX.pdf from Woodheads' site. it has a complet chapter on the configuration of te PFB-CLX module as a slave, and the different parameters you need to setup in the Controllogix Tags.
hope this helps,
Daniel Chartier
Hey guys, I recently had to change out an old eaton drive from our WWTP with a newer DG1 Eaton drive. I had to install a DXG-Net-Device net...
3,799
Hi all, Now I am working with Sicam P50 multi function meters. It have 2 sets of Analogue outputs. I want to know how we can check its working or...
1,521
Hi there, I have little annoying problem with configuring Alias Topics in RSLinx Classic Gateway. I created two drivers for each PLC in redundant...
2,660
Hi, I am fairly new in the PLC industry, and my latest job for me to complete is to test a panel with a single output module (Spectrum Control...
1,788
I have to load a project to a PLC 5 processor via DF1 protocol. I have a laptop with a PCMK card in it with the 1784-PCM5/B Cable. I have to...
2,378
