Help OMRON CJ1M communication
Joel201
Nov 2013
Calamba City
151
Hello,
Is it possible to communicate my laptop with a CJ1M using a regular usb to rs232 cable? as i dont have laptop with rs232 port. Can you give suggestions on what i can do to communicate with a CJ1M PLC
Thanks,
Joel
The Omron 9 pin connector is NOT a standard pinout.
Also, USB to serial converters are not all the same.
There are many posts in the forum regarding converters.
The Omron CS1W-CIF31 is very reliable. Not inexpensive, but it works.
Here is the Omron pinout.
Is the DB9 just a standard RS232? I have not made a cable for it but maybe I should... I have a few CJ1G's (CPU44H) and a few others that I can test them on but it would be nice for my customers to have another option other then the CS1W-CN226
Joel201 said:
Can i use the SIEMENS MPI Cable to communicate my laptop with CJ1M PLC?
No the MPI cable will not work, it is MPI and 485
Hi Mark,
The DB9 port is RS232. You need to be careful, because the protocol can be changed depending on what is connected.
For programming is needs to be set for Host Link.
There is a dip switch that can be set to make the port default to Host Link.
The CS1W-CN226 connects to the peripheral port. I think your C200HS-CN220-EU cable will work properly to the DB9 port on the plc.
JOEL201,
geniusintraining has cables available and is a great company to work with. I use his cables and have not had an issues.
Hope this helps.
Another approach is you use a PCI Express RS-232 adapter card. They tend to be much more reliable than the USB serial converters. You will still need to buy (or make) a CN220 cable as gtsuport indicated.
Can i just connect a standard db9 conenctor with a standard usb connector without the converters? can you give a wiring diagram if possible.
Thanks,
Can you give the USB to RS232 wiring? so that i can make a cable i am not that familliar with omron communication so i hope you can help me
Dear all, I have one CJ1M CPU 13.. I am trying to communicate using CS1W-CN118 and serial to USB converter CS1W- CIF31, I am using Cx programmer...
7,868
I am working with Omron CJ1M CPu22, I need to know that How to take input from an HMI by Placing the value in Counter. I have placed a Flow...
4,756
I just got a new Omron CJ1M-CPU11-ETN with ethernet capability hence the ETN. I am trying to set up the ethernet with the manual and am having...
2,396
We have an omron CJ2M-CPU12 PLC that we are having issues with an AD04U analog card. it is connected to a K type thermocouple sensor. The card is...
608
Hi all, While i am not new to omron, i'm totally new to the analog part and lost. i have a CJ2M cpu 33. then there are 4 i/o cards card 5 is a...
26
2,589
