help on micrologix 1400
aaron_01
Sep 2014
manila
Hello, I was wondering if anyone can help and point me to a rs-485(rs 232 female) diagram of the pinout of a AB micrologix 1400 on ch2. currently im testing/studying application of a modbus rtu master into communication with a inverter drive w/ rj45 (rs485)with a terminal label (EV,sg+,sg-,gnd). thanks in advanced...(y)(y)(y)
Not sure if Channel 2 can be used as a 485.
Per AB Pub. 1766-um001:
Connecting to Networks via RS-232/RS-485 Interface
The following protocols are supported from the RS-232/485 combo communication
channel (Channel 0) and the RS-232 communication channel (Channel 2):
• DF1 Full Duplex
• DF1 Half-Duplex Master/Slave
• DF1 Radio Modem
• DH-485
• Modbus RTU Master/Slave
• ASCII
• DNP3 Slave
RS-232 Communication Interface
The communications port on Channel 0 of the MicroLogix 1400 controller utilizes a
combined, isolated RS-232/485 interface. RS-232 and RS-485 are Electronics
Industries Association (EIA) standards that specify the electrical and mechanical
characteristics for serial binary communication. They provide a variety of system
configuration possibilities (RS-232 and RS-485 define electrical connection characteristics,
not protocols).
The MicroLogix 1400 controller supports an additional, non-isolated RS-232 interface
on Channel 2. One of the biggest benefits of an RS-232 interface is that it lets you
integrate telephone and radio modems into your control system (using the appropriate
DF1 protocol only, not DH-485 protocol), but it is for point-to-point connections only between two devices.
Pretty sure CH2 is RS232 only on the ML1400 - you will need to to use CH0 (8-pin mini Din) if you want to use native RS485.
Personally i would use a 1763-NC01 to allow easy connection of the RS485 interface.
Regards,
Rob
oh i didnt know that since micrologix 1400 on rslogix ch2 settings can be configured as a modbus rtu thanks for the help... (y)
instead ill use the df1 cable terminal 1 for data b+ and terminal 8 for data a-, terminal 2 for gnd evrything made sense now
Hello everyone, I'm having an issue trying to get a messaging instruction to work. I'm trying to get some data from a Micrologix 1400 to a L83E...
18
6,193
Hello again everyone. I'm converting a current monitor program from a ML 1000 to a ML 1400 processor. This is the same one where I was struggling...
1,886
Hi there, I seem to be having some issues interfacing a Mircologix 1400 and a Panelview plus 1000. All communication is done over ethernet...
2,384
Hi Im new in PLCs please i need help to make a backup file of a program in ML 1400 what is the way to upload this program to my PC and if this...
6,395
Dear colleagues, urgently need your help. I need to add flip flop logic for pumps in my code. Now the logic is: We choose the tank and start pump...
2,011
