Micrologix 1400 Help.
JeremyF
Apr 2018
Nebraska
Hello again everyone. I'm converting a current monitor program from a ML 1000 to a ML 1400 processor. This is the same one where I was struggling with the indirect addressing about a week ago. Thanks for all the help, the addressing is working now!
About this program. I'm monitoring the grinding wheel current of an engine valve seat grinder. I can set a hi-low limit, and if the grinding wheel current goes above or below my setpoints, it opens a reject gate for the valve to go to so the machine operator can inspect the valve. To help them set their high, and low values I'm sending the grinding current of the last 16 valves to an HMi display. I'm also trying to show them the highest current, lowest current, and the average current from those 16 valves. Here is where I'm struggling. The high and low current steady stay 6244 and 0. I don't even know where these values are coming from. I'm going to try to attach a few screenshots of the part of the program that works on the High and Low. Anyone see something I'm missing?
Thanks again for the help!
Jeremy
In your first screenshot Rung 1 you reset the counter C5:3 then you move C5:3.ACC to N7:70; it will be always 0.
The reset instruction have to be after the Move instruction, so you don't miss the C5:3.ACC current value
Hello everyone, I'm having an issue trying to get a messaging instruction to work. I'm trying to get some data from a Micrologix 1400 to a L83E...
18
6,193
Hi there, I seem to be having some issues interfacing a Mircologix 1400 and a Panelview plus 1000. All communication is done over ethernet...
2,384
Hi Im new in PLCs please i need help to make a backup file of a program in ML 1400 what is the way to upload this program to my PC and if this...
6,395
Hello, I was wondering if anyone can help and point me to a rs-485(rs 232 female) diagram of the pinout of a AB micrologix 1400 on ch2. currently...
2,074
Dear colleagues, urgently need your help. I need to add flip flop logic for pumps in my code. Now the logic is: We choose the tank and start pump...
2,011
