help required
bryans_mark
Nov 2002
scotland
Hey. Can any one tell me which type of plc to use. Im a second year engineering student at glasgow university. I've got a project this year to design a holding unit for large pieces of wood. This unit must rearrange the work order of these logs and i've been told that a plc is the correct control unit to use. The only problem is that i don't know anything about PLC's. PLease help.
Determine inputs first
One of the first things you need to determine is how many and what kind of inputs will you need on your PLC. Then you will have to determine what kind of outputs you would like the PLC to control. After you have that, you can decide what kind and size PLC you need. I always tend to "oversize" my PLCs so that in the event the higher ups want to make changes, more than likely the PLC will be able to handle it.
Good luck.
Best regards,
Craig
There are a number of different companies that manufacture PLC's. GE, Allen-Bradley, Omron, Seimens, Keyence, and Automation Direct to name a few. They all use different software and program a little differently as well as come in a broad range of sizes and cost. As cdobis said the first thing you need to do is determine your I/O so you know what size PLC you need. Once this is determined my guess would be that your next worry would be cost. Assuming your paying for this yourself you would probably want to start out looking at Automation Direct. There equipment is pretty affordable and you can purchase it right off the internet and pay with a credit card.
Good Luck.
Hey, we got a machine from China (yay hooray -.-) that has some really annoying flaws. Like the HMI screen is going off after a minute which is...
2,176
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,846
I have a small application where I need to spec out an actuator. The load is 7kg and needs to move 90 degrees around a 1cm diameter in 1 second...
1,857
I'm currently trying to open an old Medoc/Melsec (Mitsubishi DOS-based PC program) Does anyone know how convert it into windows based program? I...
2,042
i am using PLC of B&R its CPU is CS0104100242. It is showing Error 23 and when i reset this error its cpu shows "INIT" and again it shows error...
1,874
