Help SCL Micrologix 1000 analog
joelfco
Sep 2010
nogales
Hi my friends
I am very grateful for the forum
I need help with the instruction SCL
I have a maximum 1000 Cº and minimum 0
in entrance of 4-20 ma
help please
atte
joel
thank my friend mickey
you have some file excel for future calculations
I will connect a variador of frequency RM5G 0-10v
I am teacher and need for students
thanks
joel
thanks
joel
Voltage input? The example I showed above is for a current input,
4 to 20ma. The input values will be a little different for a voltage input. See picture below . This would change the rate and offset values if using the "SCL" instruction.
No spreadsheet, just notebook paper and pencil
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
343
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,085
Hi, Can someone translate this for me please, or at least help to explain what the instructions mean? SET SAVE =...
17
4,634
Hi guys Its been some time since I worked with SCL and have a few lines of code I need some help with, I have the SCL raw code and am currently...
1,508
Working with a SCL instruction and need a little help. The logic is a Heat / Cool circuit controlled by a PID. The PID Zone_4.CVEU tag is coming...
3,173
