Help - Using 1771-OFE1
christiansjp
Jan 2011
Tampa
Hello ererybody!
I have a great doubt,
have a plc 5/20 with a module 1771-OFE1(0-10 V) and can not increase the size of the chassis.
Can I use one output to two devices?
Any help would be great.
Yes, you can wire the Voltage output of a 1771-OFE1 to more than one device. They will need to be, as you said, the same signal range. Wire them in Parallel, not Series.
You must be aware they will both receive the same signal voltage?
Yes, voltage signals are necessarily driven into high impedance loads, and paralleling them is OK (up to a limit of course). You will have no problems with two devices.
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
612
I'm new to Crimson (this is my first week, and I just ran into my first road block. I'm trying to display the position of a rail car, running in...
1,184
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,888
Hi all I am trying to set up a lhttp instruction to connect to an api https (with our IT) this will send data back to the plc? I have an api https...
1,832
please help i didn't solve this problem with rslogix. I counted but i am not using timer. How i will fix this situation? Please anyone solve this...
18
5,012
