HELP -USING VMWARE to connect PLC
shanoobvs
Mar 2014
UAE
HAI ALL.
I am new to automation field.Can somebody tell me how i can use vmware to connect/troubleshoot PLC using my laptop
thanks all..
Hi
To what make of plc, using what comms, what port,
What operating system on both the host and vm machine
Also what have you tried and what problems are you having
If you give more information you we'll get a better answer
Donnchadh
VMWare is like having a brand new computer running whatever operating system you require. Only, it is running virtually on your own computer. So I can launch my Windows 8.1 PC and do what I need to do. Then when I need to work with say Rockwell equipment, I boot up a virtual machine running Windows 7 where I have all the relevant software installed. I might have a separate virtual machine for Siemens, and maybe another virtual machine running Win XP for another vendor. This cuts down on the possibility of the Siemens software "breaking" anything on my Rockwell or other systems.
In this example, The Windows 8.1 would be referred to as the "host" operating system. The Windows 7 and Win XP would then be referred to as the "Guest" operating systems. Once you power up that guest, you can do with it whatever you would do with a real computer. Connect USB devices, connect to an Ethernet network. Treat it like a real machine.
OG
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
564
I'm new to Crimson (this is my first week, and I just ran into my first road block. I'm trying to display the position of a rail car, running in...
1,161
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,860
Hi all I am trying to set up a lhttp instruction to connect to an api https (with our IT) this will send data back to the plc? I have an api https...
1,788
please help i didn't solve this problem with rslogix. I counted but i am not using timer. How i will fix this situation? Please anyone solve this...
18
4,921
