hi speed input
thacks
May 2007
england
i have a siemans step7-200 plc.
I0.0 and I0.1 are both hi speed inputs 100k each
I'm having a few problems with the program. What i've got is a encoder input running at 30000 pulses a second all i want to do is run a output at 4/1 ratio or 4 input pulses to 1 output pulses i've tried using a counter to control a output but it's way to slow i've also looked at the HSC counter but can't get my head around the code any help or ideas would be great any code would be even better
from what i know, siemens s7 200 PLCs have an input of 10k/second (I may be wrong)
but why dont you use a Frequency to voltage convertor and then connect voltage to the analog input of the PLC(if you have one), this way you can use Logic to control the amount of pulses at Q0.0 and/ or Qo.1 (these are high speed outputs I believe) look at the instruction wizard in microwin..and take a look at PTO..
I dont know why you wanna do this though..I just hope I gave you some Ideas..Khalil
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
137
Hi, I have a setup of one master s7-1200 - three slaves s7-1200 On each of the slaves there is a HSC on a motor for positioning. It generates...
1,104
Working on 2 VFDs for two motors, they follow any speed command when local and in hand. Once I try to give a Speed reference from my PLC they both...
2,231
Hi all I am going to read gaps between product by millmeter to accept or reject product, with RsLogix 5000, The problem is : when the speed...
1,426
Unitronics Samba plc I am working on a system that uses the High Speed input on a plc to calculate the rpm of a shaft. It is having issues with...
20
5,608
