High speed outputs
Daronsirmon
Jan 2007
WESTON SUPER MARE
Hi i am trying to get a Mitsubishi Fxon plc to operate a solenoid valve on and off at high speed, ie it's firing a glue gun on and off, cant seem to get my head round it, any ideas.
It seems due to iL (0+ ) = iL (0- ) at commutation moment
and if safety diode present in DO extention board you have solenoid release delay.
If it is, you have to decrease reactivity of load (solenoid) by connection resistor in parallel. Approximately R = 2RL .
What can't you get your head around ? The Logic or problems with the firing ?
Some things to take into account
Switching time of output of plc
Response time of solenoid, AC or DC
Scan Time
Depends how fast your switching is i guess!
I fire glue guns on packaging machinery in 50% duty cycle starting from 10ms alteration with no problem.
I use Festo and Mac 24VDC ~5W solenoid valves.
PLC is FX1N but used to be FX0, FX0S, FX0N.
2/sec is so slow ...
Should be no problem at all.
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
131
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
86
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
749
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,406
Hi, I have a setup of one master s7-1200 - three slaves s7-1200 On each of the slaves there is a HSC on a motor for positioning. It generates...
1,091
