HMI connection
moody088
Nov 2008
checago
38
Hi ,,,,,
Use a drag-and-drop operation to insert those components into the configuration table of the SIMATIC PC station that represent the configuration of the real PC. The components are located in the "Hardware Catalog" window under SIMATIC PC Station:
- SW placeholder for configuring connections such as "User Application" or HMI components (if installed) also in slots 1 to 32
how can i install the HMI in simatic manager ( the HMI is TP 177B PN/DP ) ?
i mean how can configure this HMI to the simatic manager ?
Open the network setup menu. On the right hand side is a list of "Networkable" items - like ET200, encoders etc. - and the TP will be in there somewhere.
Drag the TP into the middle of the screen then click on the unit and drag a line up to either MPI or Profibus (Or both). Both the TP and your plc will have a small number displayed in the middle - indicating its node address.
I frequently use non Siemens panels so drag "Other station" in.
I haven't got the software in front of me so hope its not too vague!!
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
95
Hi gents I have weintek HMI (MT6070IH) and s7-200 plc cpu 224 and vfd which supports rs485 modbus rtu communication. The plc has 2 ports, one...
802
Hi! I'm an intern and a newbie in the field of automation. I was given the assignment to learn and program a PLC and HMI together. PLC: Delta...
2,008
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,593
Ye..llow everyone! I need some help on this: I have TIA project with an Siemens HMI connected to an OPC server. This HMI has the file name...
973
