HMI OMRON NS5 - Control/Notify Area
czarny87cd
May 2012
Kraków
Hi everyone !
Maybe someone with users working with HMI OMRON NS5 series or guys with more experience will solve my question.For NT31C I set in PT Configuration Control/Notify Area, but in Cx-Designer I can`t found any similar options which will be set this parameters. I suppose, in case when I set memory address area in the PLC that will be shared between the NS and PLC and Control/Notify Area is unnecessary.It`s true ?
Here are my notes regarding your subject.
NS – Control / Notify
The equivalent of the NT PT Control and PT Notify areas can be in the NS internal memory (default) or in the PLC memory.
To change to PLC memory:
Set up in NS Designer: Settings/System Settings/Initial/System Memory
$SB uses 64 bits (4 words must be contiguous)
$SW uses 41 words (must be contiguous)
Function of System Memory Bits and Words is defined in the Programming Manual #V073-E1-06 – Section 2-4.
Note: First word in $SW ($SW0) is the current screen register. It displays the current screen number and will cause the screen to change if a valid screen number is entered (similar to first word of PT control in NT screens).
Note: Screen 0 is a valid screen number. Screen number must be in BCD.
Starting with System Version 7.0 a NT compatibility mode has been added.
Refer to manual V073 – Section 2-4-3.
Hope this will help.
Hello
There is an equivalent
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
292
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
888
Hey everyone, I'm new to this type of HMI and I have a couple of questions. 1) I'm creating a screen with text on it and base font is "DFNB-EN"...
422
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
