How to assign IP with the sinamics motor module?
chandrapaul
Mar 2016
bangladesh
119
Hello,
Someone please help me. Kindly let me know how to assign IP with the s120 sinamics motor module /line module /interface module and the g120 power module? Can I do it using starter software or any other way? If there is any reference video or manual please give me link.
I am new with Siemens drives. Please help me.
Thank you
For s120 the only IP address assigned is for the CU320. All connections between the CU/LineModule/MotorModule/InterfaceModules are via Drive CliQ
If any motor module /power module /line module /interface module get damaged under the s120 CU and if we replace the damaged module with a exact same module, then should I assign the ip/name newly for the new replaced module or will it take the ip automatically from the CU?
As they said, only the CU has an IP. You don't assign IP addresses to the motor modules/line modules/etc. They are on DriveCliq, which uses cables that look like Ethernet cables, but is actually NOT Ethernet, but backplane communication.
What you DO need to do (I think) is ensure that the drive cliq topology is the same. When you replace a module, make sure the cables all end up in the same places.
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,045
On my HMI-1200, I'm trying to assign the image of a floppy disk ("save" icon) to a function key. I couldn't find one in the default drop-down...
607
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,140
Good Morning, I'm not sure if this is a stupid question, but I've been working with FTView ME for quite some time now and I can't solve this...
1,499
Hi I have a few Movimot motors on profinet, where i need to change the profinet name on the motor. I have been true this before, where i deleted...
2,441
