How to configure additional MPI port with WinCC Flex on Panel PC 677B
Jack Schit
Oct 2009
England
35
Hi All,
I currently have a WinCC Flex project running on Simatic panel PC 677B with a CPU 315 2-DP PLC communicating over MPI.
I would like to add an extra PLC (another CPU 315 2-DP) to the WinCC Flex project also communicating over MPI.
However, the panel PC only has one MPI port. Is there some way around this e.g. USB to MPI etc...
Jack
Hi Jack.
I am not 100% sure, but I think it is not possible.
Why not connect both PLCs to the same MPI network ?
If this is a new project, I strongly recommend to think about ethernet in stead of MPI.
If Ethernet/MPI network isn't an option, then a netlink (MPI to Ethernet) can be used with WinCC flex runtime to achieve what you need.
I think you are right STL.
It depends on that the netlink can work with a different access point than the standard S7ONLINE, like S7ONL2 for example.
This because there must be two different accesspoints in WinCC Flexible for the two connections.
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
163
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
239
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
151
Hi all, the machine I am programming the Rockwell PLC for has about 100 parameters that need to be adjusted for every customer. I would like to...
20
1,976
Within the last week or so, PME has crashed whenever I try to open a configure IO screen. I am running V8.0 Build 6215. Offline configuration of...
400
