Philadelphia Frank
When I connect my laptop to a Compactlogix PLC through the ethernet port, I need to set up the IP address of my laptop so the first three octets match those of the PLC. If the PLC is 170.10.50.100, my laptop must be 170.10.50.xxx.
What do I do if I need to connect to a PLC with an unknown IP address? I know there is a DOS command "ping" that can be used to verify a connection between the laptop and PLC, is there a DOS command that will show what devices are on a network?
Is there a way to set up my laptop so RSWho will show devices on the network even if the first three octets don't match?
Thank you for your time and help;
Frank
Frank
