how to disable printer port in PanelView 550
sanjay_snj
Jan 2004
ABU DHABI
36
i went to the configuration mode in panel view 550 and went to printer set up page. i found the port was enabled. i tried to disable it by pressing F6 button (as these are toggle buttons), but it is not getting disabled. i tried other kunction keys, and found them working.
can any one help me
sanjay
IF the printer port is configured in the panelview program then it cannot be disabled if use downloaded configuration settings is set in the application. See below;
Configure the printer port
Most PanelView terminals have an RS-232 that supports printing. (The PanelView 300 Micro terminal does not have a printer port.) The communication and print parameters for this port are defined on the Printer tab of the Application Settings dialog.
On some terminals, the RS-232 port supports both downloading applications and printing. The Auxiliary Port Usage area of the Terminal Setup dialog shows how the port is being used. If printing is enabled, the port is configured using settings on the Printer tab.
To edit the configuration of the printer port:
1 On the Application menu, click Settings.
2 Click the Printer tab.
3 Under Auxiliary Port Setup, set the communication parameters for the port. The initial defaults are:
Baud Rate 9600
Parity None
Data Bits 8
Stop Bits 1
Handshaking None
4 Under Printer Configuration, define the format for printing pages and the string that will initialize the printer after communications is established. The initial defaults are:
Left Margin 0
Page Width 80
Perforation Skip Value 6
EOL Char CR
Page Length 66
New Page Control Form Feed
Printer Initialization String Null string
5 Click the Save as Defaults button to save the current settings as the default.
If you don’t save the settings, they will revert back to the original settings when you exit the dialog.
Notes
§ The printer port settings are downloaded with the application if Use downloaded configuration settings is selected on the Power-Up tab of the Application Settings dialog.
§ On the Printer Setup screen of the PanelView terminal’s configuration mode menu, select the Top of Form setting to verify that the terminal and printer are both set correctly.
Allen-Bradley Company, LLC, Copyright © 1993-2002, All Rights Reserved
Hi to everyone, I'm writing from Italy... I'm trying to disable the rs232 printer port of an AllenBradley Panelview 600 but I can't reach my goal...
6,774
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
202
How can we disable the DHCP server on a Stratix 5700 ethernet switch? It is running on a machine with Rockwell automation and drives. We...
1,624
Hello. We have a Powerflex 700s phase II firmware 4.002, but the encoder card is burned. We want to disable it to use the Drive without motion...
471
As above. I've been fishing around on TIA portal but haven't found a "Disable channel" tickbox. Is there one? If so, where is it? Cheers
1,371
