How to know when KEPServerEX will require tags?
I just got another reply from that Chris Morehead guy and he just doubled down pointing to the product page saying they're all PLCs with safety features and KEPServer don't support that. But the knowledge base article that he linked to talks about GuardLogix devices which I already told him this PLC is not. That's the MS version on the part number.
been there done that. I asked a question about changing the tcp port number used in kepware and the chick came back and asked why I was trying to use ethernet with a micrologix 1400 that it didnt have an ethernet port.
I believe I mentioned that...
Sorry, didn't know what that meant. :(
Not knowing all the details/Hows/Whys, it just seems odd for a read to be ok but for a write you have to tell it the data type. Another guy swears he did a project and did not have to do that. ???
Does anyone know if it's possible, or the best way to go about adding a generic/ placeholder/ empty/ dummy tag to kepware? I used auto tag...
1,418
We are updating A few older Aveva Wonderware InTouch applications from a SLC PLC to a new ControlLogix PLC. What is the best way to deal with the...
1,090
I've setup another VM with KEPServerEX but it will not talk to the same PLC that the other is. It is seeing the PLC as it will show another error...
2,424
KepserverEx v6.11.718.0 Studio 5000 v33.00 Has anyone ever run into an issue with adding strings (that are part of a UDT) into Kepware? In other...
1,895
I am trying to find PLC simulation software that will connect with KepServerEx, in order to learn and test an OPC UA solution. My Siemens trial...
1,402
