how to read direct link tags in VBA?
briana banks
Jul 2005
242
Hi All
Using Rsview SE.
in my plc I've created 2 dim array (12X31) which is some form
of a calendar.
I want to write a small vba function that reads values
from a "start date" to a "stop date"
I know how to read HMI tags but I didnt create any.
How can i read directly from rslinx?
Hi
well this will force me to make a display with 365 NumericDisplays
This is a little bit awkward solution
It takes almost 15 seconds to load such a display.
Is there another way?
Shouldn't take that long. Post your code if you can
I have found the 1756-EWEB much faster. 1000 tags in about 3 seconds
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
153
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
126
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
255
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
101
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
149
