A standard usb key can hold both evrsi activations as well as factory talk activations. I am doing both on the same key and it is just an off the shelf unit from best buy.
You do need a special version of evmove called evmove CF to get the activation onto the USB drive
Hope that helps
Marc
PS i have this text on my jump drive so I don't forget. If you use evmove, the activation will be lost!
Use EVMOVECF to move the activation FROM the Master (floppy) disk, or harddrive, TO the USB Flash Drive
- EVMOVECF looks and operates just like EVMOVEW, the difference is that EVMOVECF is designed to recognize Compact Flash Drives.
Use EVMOVEW to move the activation FROM the USB Flash Drive TO the Harddrive of the designated machine
I don't move them after the first transfer, I just plug in the jump drive and Rockwell Software finds it on the drive
