how to run rslogics on a desktop and a laptop
Hi Joe,
IF you are using the floppy as your key (so the older version) you can use the floppy to move the key to your laptop... then use the floppy without the key to run your desktop.
I have not tried it before but I am 99% sure you can
Also like I said you need the older floppy version of the key
the newer versions which no longer use the floppy can use a USB key that you must purchase seperately. you cannot run both computers at the same time.
A standard usb key can hold both evrsi activations as well as factory talk activations. I am doing both on the same key and it is just an off the shelf unit from best buy.
You do need a special version of evmove called evmove CF to get the activation onto the USB drive
Hope that helps
Marc
PS i have this text on my jump drive so I don't forget. If you use evmove, the activation will be lost!
Use EVMOVECF to move the activation FROM the Master (floppy) disk, or harddrive, TO the USB Flash Drive
- EVMOVECF looks and operates just like EVMOVEW, the difference is that EVMOVECF is designed to recognize Compact Flash Drives.
Use EVMOVEW to move the activation FROM the USB Flash Drive TO the Harddrive of the designated machine
I don't move them after the first transfer, I just plug in the jump drive and Rockwell Software finds it on the drive
You could also network the 2 together and map the drives then move the activations to/from the mapped drive. You could also install virtual pc 2007 with any os and move the activation to it then shut down save changes and restart. Now move the activation back to another drive, shut down virtual pc without saving changes and voilla you now have 2 keys.
You may use a usb NIC and it's hardware address as a Host ID the same way you would use a dongle. Or, if the two computers are on the same network, you can use one as an activation server and let it loan out the license as you move between machines.
Several years ago I ditched using a desktop. Now I have only a laptop + docking station + a big monitor & full sized keyboard. When I'm at my desk I dock the laptop. Its the best of both worlds and I never have to mess around with transferring files between computers.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
32
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
144
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
86
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
285
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
355
