How to simulate the signal in RSlogix5000
jcp
Feb 2010
Multan
369
Hi friends;
I have a Rslogix 5000 version 13. In the logix programe i do the following steps;
1. Go onlone and the controller is REM RUN mode.
2. Then open that routine in which final value of signal is compute through some function block. The value is controlled the flow control valve 0 to 100% openning. I want to check to give a diffrent values. The output is comming finally from the HLL. I press the corner button on this block a window open in which diffrent parameters are shown like ENABLE IN, ENABLE OUT etc. But the output and other parameters are Grayed. How can i change the value to check storke of the valve?
3. I also want how the forces are applied if i want to check the I/O device? which bits i can not force or which i force?
HI;
Generlly i want to ask how to manipulate the signal and force in rSLOGIX 5000?
Regards
Kinda off topic but does anyone know of an easy way, simulator, etc. to simulate a 5 amp 3-phase CT signal into a power meter? I know they exist...
2,791
Hi friends; I am new witth that speed sensor. I want to simulate the speed signal plz guide me how can i simulate it? I have Fluke 741B and...
2,399
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
109
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
547
Hello everyone, i would like to test and run os server in pcs7 v8.2 project without rear PLC.i used plcim on ES and nettoplcsim and adjust the...
1,336
