HSC Help
zblum
Mar 2016
Ohio
38
I am having trouble utilizing a MicroLogix 1200 HSC to trigger an event.
I have the HSC mode set to 0, because I want to trigger an event every 'x' number of pulses from my encoder. With the mode set to 0, the accumulator resets when it reaches the high preset.
The problem is, I'm not finding finding a variable in this mode to trigger my event. The 'mode done' bit just turns on after the first cycle and never resets.
And would the counter belong in the HSC file, or the main file?
Can you just use a GEQ block to compare the accumulator to a preset value that resides outside of the counter function? And just incremement the preset to the next "step" every time you cross it?
Rockwell has a word document on the internet that helps with setting up the HSC for various things... might be for a ML1100 but should be similar to the 1200.
I have been referencing the HSC manual, but I have not found it super useful. I learn best from examples, and the manual has ZERO examples when they discuss the function.
I think my problem is that these "steps" I am watching for occur so frequently that I need to use some sort of interrupt to catch them. And I thought the HSC would serve that function, but it hasn't.
Hi everyone, I have a Micrologix 1400 using an HSL instruction (High Speed Counter Load). This instruction is used in junction with an encoder...
829
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,108
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,390
So I have to encoders with A,B and Z pulse 360 encoder wired up to A0+, B0+ and Z0+ and the - pulses wired to common 24vdc. I can see the inputs...
1,045
Hello All, This is my first time working with encoders and I am a little lost. I have a 1769-HSC/B card on a Compactlogix L32E controller running...
3,019
