HW Updates in Step7
JiNCs
Jul 2007
South Carolina, USA
66
Hey folks,
I have to replace a hw device in the HW config. When I tunnel down in the tree on the right side of the HW window and get to the where I think it should be I don't see it. I have a 315-2 DP CPU and 'tunneled' through SIMANTIC 300/SM-300/DO-300 looking for a 6ES7 322-1EH01-0AA0, 16bit 120/230vac 0.5a digital output module. Its not there.
If I look in catalog profiles I see it but cannot get it to where it shows in the usable tree.
Am I looking in the correct tree folder? Can someone help with getting either the HW config updated with this module and/or get the module from the profile to the tree?
Thanks . . . as usual!! o_O
JiNCs
Yes you are looking the right place.
When your PC is connected the internet, perform a "install HW updates" in the HW Configurator.
The mentioned output module should be available with all STEP7 versions.
Dont think there is a big difference to the previous version 6ES7322-1EH00-0AA0.
Thanks JesperMP.
Not sure what I was doing earlier today but I thought I downloaded the updates from the internet and then installed them. I guess I wasn't holding my mouth right. :oops: When I looked I didn't see the module. Maybe I overlooked it.
I followed your instructions and there it was.
You're right, its probably not much difference between the modules.
Thanks again
JiNCs
https://www.reddit.com/r/PLC/comments/187sy3w/rockwell_is_straight_out_dropping_some_heat_today/ :site:
461
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
596
I am having a weird experience using KepwareEx6 as an OPC Server for a set of SLC processors where the tag data is not updating remotely at the...
589
We upgraded our systems to FactoryTalk Service Platform 6.31 and ran patch roll up from Dec 22 after software updates. We have a network...
1,480
I use iQ works and RT toolbox and have licenses for both. I usually go to mitsubishi's site to download latest versions. First question when...
1,765
