I need the change coros op25 to op27...how to?
I think you only need a null modem cable (RS232). I will confirm.
I think you can also use a standard Profibus cable
It is NOT possible to upload a project file from an OP25 in order to migrate the project to OP27 or other newer panels.
You need the source Protool project. With that you can migrate to a newer panel.
Also look HERE.
First you will convert OP25 program into OP27 with Protool software. Then you will also a sign op27 in profi bus node if it is connected on profi Bus.
i connected pc to op27 with profi bus . and convert project file from op25 to op27 Finished
and when i upload to op27 have a error4004: no connection to op?
how to fix error
Connect Op27 with PC through op27 programming cable RS232. Switch off OP27. Press UP and left arrow key and switch on op27 supply. Op27 will go to transfer mode. Then you transfer your project with protool and RS232 programming cable.
Hey everyone, I am upgrading Modbus from MVI-56MCM to MVI56E-MCMR? Do I need to change in IO Configuration? I don't know if it is Master or...
1,376
Hello, I've got a program from a customer for a Micrologix, but can't open it without upgrading to a newer version of RSlogix 500. Could someone...
1,021
Good Afternoon , I was emailed a RS Logix 5000 program that is version 32. I only have version 28 , on this computer here at the house. I...
4,496
Hi guys....first post here. It's been about 6 years since I worked heavily with PLC's and automation, but I'm getting back into it. I was hoping...
20
3,603
Good Morning , We are going to need to change a gearbox that as a MPL-B540K-MJ24AA connected to it. The gearbox is 19.5 : 1. The problem is...
4,390
