I/O ControlNet setting in Fanuc R-J3i ?
wendaiyu
Jun 2014
toronto
87
Hi, folks, how’s going?
On our production line, we connect Fanuc R-J3i robots to Logix5000 via ControlNet.
I checked one of robots and the configuration of DI is like:
DI [1-128], Rack 85, Slot 14.
I know rack85 means ControlNet, then I looked up the I/O ControlNet setting:
Board: 1
Motherboard: Full-slot
Operation mode: ADPTR
Param Change Mode: NET ULK
Input error state: ZERO
Scanner Err sevrty: STOP
Adapter Err sevrty: WARN
ControlNet Parameters:
MAC-ID: 14
NUT (us): 5000
SMAX: 32
UMAX: 32
Slot (us): 17
Gbpre (10us): 15
Gbstrt (10us): 11
Gbcenter (10us): 8.
Could someone tell us what they are? How they work?
What is the difference between MAC-ID and Slot (us)? Because we use slot 14 in DI configuration not 17.
Thanks a lot.
That word "Slot" refers to "Slot Time".
It's part of the low-level timing of ControlNet, like the three other Guard Band (gb___) timing parameters listed after it. It's almost never configured by the end user, but rather set up by the configuration software (usually RSNetworx).
You can read up on how the NUT, Smax, UMax, Slot Time and Guard Band work, but those timing and network addressing parameters don't have anything to do with how a robot or PLC controller manages its "racks" or "chassis" or "slots".
Hey everyone, looking for advice in this particular scenario. Currently we have a controlnet bus that has (6) CN2DN devices and (2) powerflex...
229
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,333
I'm having an issue trying to backup a ControlNet network. Within RSLogix5000, when I click on Module Properties of the 1756-CNB (Rev 5.001), the...
880
An issue occurred at an organization here in whereby the ControlNet card developed a fault. Card Details: Catalog/Series; 1756-CN2RXT B Part No...
454
Hi, We have ControlLogix installed at my plant with Flex IOs communicating with controller through ControlNet module. Yesterday, while controller...
498
